Jeaneggert
Jul 19, 2023Follower
Nighthawk mesh WiFi 6 mr60 setup
I just switched to T-Mobile internet want to use my nighthawk extender, when I go to setup it can not find router.
michaelkenward
Jul 20, 2023Guru - Experienced User
Can you explain that in a bit more detail?
You have a modem/router from T-Mobile and want to use an MR60?
What is this T-Mobile thing and how is it connected to the Internet?
Where are you looking for the router in setup?
If you cannot turn off the router bit of whatever T-Mobile provided, you can use the MR60 in access point mode.
