afgarcia86
Jan 17, 2023Tutor
Nighthawk Mesh WiFi 6 Multicast Issues
I am having issues connecting to a named local address via WiFi however I am able to connect when the device is connected via Ethernet. example: ``` ssh root@something.local ``` I am able t...
- Jan 17, 2023
This may have been an issue on my end. apologies...
michaelkenward
Jan 17, 2023Guru - Experienced User
Which Netgear device are we talking about here?
And the usual boilerplate questions to rule out the frequently troublesome issues.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Get those out of the way and you can move on to your specific issues.
afgarcia86
Jan 17, 2023Tutor
Totally fair I will try to answer below, I am a total newb when it comes to network stuff:
Device: MR60
Firmware Version: V1.1.7.134_2.0.65
Modem: Nighthawk CM1200
I have the MR60 plugged into the first port.
- afgarcia86Jan 17, 2023Tutor
- FURRYe38Jan 17, 2023Guru - Experienced User
May be know what seems to have solved this for you so other can know if they run into this?
