afgarcia86
Jan 17, 2023Tutor
Nighthawk Mesh WiFi 6 Multicast Issues
I am having issues connecting to a named local address via WiFi however I am able to connect when the device is connected via Ethernet. example: ``` ssh root@something.local ``` I am able t...
- Jan 17, 2023
This may have been an issue on my end. apologies...
afgarcia86
Jan 17, 2023Tutor
Totally fair I will try to answer below, I am a total newb when it comes to network stuff:
Device: MR60
Firmware Version: V1.1.7.134_2.0.65
Modem: Nighthawk CM1200
I have the MR60 plugged into the first port.
afgarcia86
Jan 17, 2023Tutor
- FURRYe38Jan 17, 2023Guru - Experienced User
May be know what seems to have solved this for you so other can know if they run into this?
