txgrl1977
Jan 28, 2022Aspirant
Nighthawk Mesh Wifi 6, Nighthawk app ver 2.14.0.301 - How to remove/uninstall Parental Controls tile
I have the Netgear Nighthawk Mesh Wifi 6 system running firmware ver V1.1.6.122_2.0.58. I am also running the Nighthawk app ver 2.14.0.301. There is a tile on my Nighthawk app "Parental Controls". I ...
Jan 28, 2022Guru - Experienced User
Factory reset the MR and setup from scratch using a wired PC and web browser. Don't enable SPC after it's setup.
Netgear has set up a community forum specifically for the Smart Parental Controls product. Most of the people who watch that forum are more likely to have experience with Smart Parental Controls. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controlshttps://www.netgear.com/home/services/smart-parental-controls/
For the MK series system, Netgear has set up a community forum specifically for the NightHawk MESH products:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
- txgrl1977Feb 01, 2022Aspirant
I did a Factory Reset of my MR60 and while I'm able to control devices (as of right now) via the web interface, I have tried reinstalling the Nighthawk app on my phone and the Parental Controls tile has reappeared, leaving me unable to control devies in the app. So the Factory Reset did not work.
I guess the next step is to post on the Parental Controls forum. This is so frustrating.
