Napoleond
Oct 08, 2020Initiate
Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
I bought an MR60 system from Costco last June. It was worked fine up until the last couple of weeks. Recently its begun dropping connections to the Satellites. There is no way that I can find to...
- Feb 10, 2022
Just purchased this about a week ago. For the first couple of days, was having the same issue as everyone else here, but since assigning the satellites static IPs, it has been rock solid. The other thing I did (as a result of having issues with my Sonos) was changed the wireless channels for both 5gHz and 2.4gHz, based on what the Wifi analytics (in the app) told me were the best channels to use. I doubt changing the channels did anything, but assigning the static IPs sure seemed to help (as suggested by another user). Just wanted to post this, to confirm what others had suggested.
ak_col
Jan 28, 2021Initiate
I have troubleshooted this with the netgear technical team as part of the complementary support and I found no resolution. I returned the item at Costcto and bought another set and again running into the same issue. I hope they have a documented solution for it
Napoleond
I switched to EERO and haven't had a single problem since day 1. I believe it is worth every penny above what I paid for the Netgear product.
Amazon.com: Amazon eero Pro mesh WiFi system (1 Pro + 2 Beacons): Amazon Devices
