Napoleond
Oct 07, 2020Initiate
Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
I bought an MR60 system from Costco last June. It was worked fine up until the last couple of weeks. Recently its begun dropping connections to the Satellites. There is no way that I can find to...
- Feb 10, 2022
Just purchased this about a week ago. For the first couple of days, was having the same issue as everyone else here, but since assigning the satellites static IPs, it has been rock solid. The other thing I did (as a result of having issues with my Sonos) was changed the wireless channels for both 5gHz and 2.4gHz, based on what the Wifi analytics (in the app) told me were the best channels to use. I doubt changing the channels did anything, but assigning the static IPs sure seemed to help (as suggested by another user). Just wanted to post this, to confirm what others had suggested.
Gamereck
Sep 15, 2021Aspirant
So guys the mesh device I bought started having issues with the internet port losing connection to the internet. After research it’s an issue that people have had with this model since 2020 and Netgear hasn’t seemed to patch the issue. So I decided to turn it from router mode to AP mode and disabled the WiFi on my Comcast modem things runs with no internet drop and the performance seems to be better.
