Napoleond
Oct 07, 2020Initiate
Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
I bought an MR60 system from Costco last June. It was worked fine up until the last couple of weeks. Recently its begun dropping connections to the Satellites. There is no way that I can find to...
- Feb 10, 2022
Just purchased this about a week ago. For the first couple of days, was having the same issue as everyone else here, but since assigning the satellites static IPs, it has been rock solid. The other thing I did (as a result of having issues with my Sonos) was changed the wireless channels for both 5gHz and 2.4gHz, based on what the Wifi analytics (in the app) told me were the best channels to use. I doubt changing the channels did anything, but assigning the static IPs sure seemed to help (as suggested by another user). Just wanted to post this, to confirm what others had suggested.
Mike_B80
Jul 13, 2021Aspirant
Nighthawk Router Mesh system is total garbage. My old WiFi with booster occasionally dropped signal. I spend 10-15 minutes a day, everyday, trouble shooting to get everything talking again. I will be taking this garbage product back.
Gamereck
Sep 16, 2021Aspirant
I have a fix that worked for me if interested.
