Napoleond
Oct 07, 2020Initiate
Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
I bought an MR60 system from Costco last June. It was worked fine up until the last couple of weeks. Recently its begun dropping connections to the Satellites. There is no way that I can find to...
- Feb 10, 2022
Just purchased this about a week ago. For the first couple of days, was having the same issue as everyone else here, but since assigning the satellites static IPs, it has been rock solid. The other thing I did (as a result of having issues with my Sonos) was changed the wireless channels for both 5gHz and 2.4gHz, based on what the Wifi analytics (in the app) told me were the best channels to use. I doubt changing the channels did anything, but assigning the static IPs sure seemed to help (as suggested by another user). Just wanted to post this, to confirm what others had suggested.
kentstation
Feb 16, 2022Aspirant
I been having numerous drops being hardwired in and through wifi.
How did you assign the satellites static IPs? Throught the Nighthawk app?
Feb 16, 2022Guru - Experienced User
You can assigned IP address reservations for the MS on the MRs web page using a PC or Laptop and a web browser connected to the MRs web page.
- kentstationFeb 16, 2022Aspirant
Thank you for such a quick reply!!
Sorry, but is there anyway you can reword that? Would this be going into routerlogin.com ?
I am very amatuer to this type of stuff.
Much appreciated.
- FURRYe38Feb 16, 2022Guru - Experienced User
Yes log into the MRs web page at routerlogin.com or 192.168.1.1 in a web browser.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
https://kb.netgear.com/24092/How-do-I-edit-a-reserved-IP-address-entry-on-my-Nighthawk-router
Much appreciated.
Thank you, after checking out the "How do I reserve an IP address," the steps 6, 7 and 8 look a bit daunting. I am unsure on what to select/type in for step 6. There happens to be 13 Address in the Reservation Table. I also see my two satelites and 11 other options which look like my phone, googe home, etc.
I tried holding in the reset button for 15 seconds on all of the devices and the drops have not happened since, fingers crossed.
