bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
mandolp
May 07, 2020Initiate
I am haing the same issue. I found that if I reboot the satalite it fixes the issue. That way I can still use the main router until the satalite is up an running. It seems that the older devices are the ones having issues connecting (ipads & chromebooks)
mandolp
May 21, 2020Initiate
I am also returned my Nighthawk Mesh Wifi. It kept driving my nuts that I had to reboot the satelite or router once a day. Got the Linksys MX10 and have not had any issues since.
- AallawiMay 25, 2020Initiate
I had the same problem but I found that I was ale to make the network much more reliable by disabling 20/40 MHz Coexistance. This is set in the web interface > Advanced > Wireless Settings.
- neonsoxxMay 26, 2020TutorI have this problem too, but have no idea why 20/40 would be enabled in my situation, so I disabled it. Time will tell. Overall, other than these odd drops and the NAT tables completely vanishing randomly, I’d say it’s a perfectly stable product ;)
