bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
jomiran
Jun 09, 2020Tutor
Firmware version 1.0.4.96_2.0.41 just hit my router this morning but there are zero release notes on it. The website still shows 1.0.4.92. Is 1.0.4.96_2.0.41 supposed to address the disconnect issue?
- NetworkGuy1490Jun 09, 2020Apprentice
MR60 / MS60 Firmware Version 1.0.4.92
New Features and Enhancements:
- Supports Japan Region.
- Fixed multiple languages display issue.
- Fixed the issue where the NH APP takes longer to enter the dashboard page at times.
- Fixed the issue where there is no satellite in the firmware update page at times.
- Niteman1978Aug 08, 2021Aspirant
Ive had the same problem. Firmware updated. Was losing conenction and was dropping.
Decided to try the hotfix on the site and it made the situation worse. Reverted to old firmware was a bit better but kept dropping every 10 minutes or so.
Got fed up and with 5 children in the house need reliable wifi so went out and bought a TPLINK for half the price and I have better range and stability.
Will call tomorrow with a case ID Unit is not even a year old.
- TOOMDAug 19, 2021Initiate
I'm having the same issues, constant dropping and totally unsable.
Another product seems only answer. Disgraceful products this bad are allowed to be sold.
- AC04Jun 16, 2020Star
I made some recommended configuration changes. Firmware update to this version and now issues are back. I rolled back my firmware to 1.04.92
jomiran wrote:Firmware version 1.0.4.96_2.0.41 just hit my router this morning but there are zero release notes on it. The website still shows 1.0.4.92. Is 1.0.4.96_2.0.41 supposed to address the disconnect issue?
