bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
Reptile8
Aug 15, 2020Initiate
I gave up. I seemed to have issues like everyone else in addition to issues with the inability to reconnect to the internet after my computer back from sleep. The only fix was to reboot the router. I have since purchased Google Nest Wifi since it seems to have gotten decent reviews, and I've had no issues after two weeks of use. It's nice to be able to come back to my computer and not have to be in a routine of rebooting the router (pulling power).
Since I bought my unit the day it was released, this isn't going anywhere but into a box on my shelf. I hope they fix things so I can eventually begin using it again or at least pass it on to a family member.
Thanks for all the updates everyone. It's nice to know so many of us are experiencing the same issues.
NetworkGuy1490
Aug 15, 2020Apprentice
NEW FIRMWARE
Guess what? Netgear released a new version VV1.0.6.102_2.0.45 which:
New Features and Enhancements:
- Fixed WiFi connectivity issue
- Fixed internet connectivity issue – one wifi client couldn’t go to internet but others are ok at same time.
This was released 3 days ago and even though I have an open case with Level 2, they NEVER bothered to notify me.
Horrible support!
- Retired_MemberAug 16, 2020
Well,
In my case, the tech support told me about this new firmware.
So i was really hoping that this firmware fix once for all the disconnection issues... But no.. from all of my devices at home (i have less than 10 wireless devices) 1 was having not connetion at all, it is an LG G6 mobile phone (strange because i have 2 and the other works ok). So i though, ok maybe its time to upgrade that cellphone, so i got a new one.. and guess what? Yes.. you are right, it also has connectivity issues.
So the issue is still there, i have randomly this message on the logs: "[WLAN access rejected: incorrect security] from MAC", but a router reboot wil solve this issue.. for.. 30 minutes until appears again.
I tried to disable even the AX and beamforming features, nothing helps.
I went back to my old WNDR3700 V1 with OPEN-WRT, no issues at all...
Netgear, the biggest disappoitment in 2020 :smileysad:
- NugAug 18, 2020TutorWhen I ‘Check for Updates’ using the app or web config page, it says there are none. Is that what everyone else gets? Sure I can manually download and install... It’s running 1.0.4.98.
Incidentally, I ran a 25m Ethernet cable from the front of the house between router & satellite and have had no dhcp issues for over 1 week. Also now getting consistently very fast speeds. - Christian_RAug 21, 2020NETGEAR Employee Retired
Hello Community,
If you continue to have issues while on firmware v1.0.6.102, please send me a private message with your email, phone, and serial number.
Thanks,Christian
- bmoney11Aug 21, 2020Tutor
Thank you for commenting in this thread. I will check out the new firmware this weekend and report back.
Since we started a new page....Here is Netgear's post (post #150, page 6):
Christian_R wrote:Hello Community,
Thanks,Christian
- Retired_MemberAug 21, 2020
Thanks,Christian
Thanks for taking care of this Christian_R
- AC04Aug 21, 2020StarI updated this morning after my wife lost connection on her IPad. So far no drops, fingers crossed.
- OceanONEDec 20, 2020Initiate
Christian_R I bought the MK62 package just 2 weeks ago and have had nothing but trouble. Day 1 everything worked fine. 2 days later ran the update to Firmware Version V1.0.6.102_2.0.45 and now everything disconnects several times a day including WIRED devices such as the Roku. Streaming has just been nothing short of a nightmare. I'm about to take a hammer to this thing. I am regretting now researching this forum prior to buying. Reading this thread, I just don't understand why has this issue has not yet been resolved? Can Netgear at least offer a firmware step-back? Or is there a fix I am not aware of?
I really want it to just work. It was beautiful for the first 2 days.
- SnorkyDec 20, 2020Star
I just sold mine on eBay. You can't rely on Netgear Support to do anything. I bought the TO-link Deco and it has run beautifully without any hiccups for several weeks, I will never buy Netgear again!
- Retired_MemberDec 23, 2020
Well...
Almost 6 months without solution....
I cannot believe this...
The onlyway that i found some "stability" with this device is use only as Access Point, levaing all the router operations to the provider´s home router (which has really lot BASIC more features than this nightpidgeon)...
Wireless channels are set fixed and security have to be AES+TKIP... with this configuration the connectivity is much more stable.
However... after a reboot... i cannot manage the device.. is giving me wireless network.. but if i want to manage it again.. i have to reset it from the reset button and setup it again... REALLY?What a shame to leave you customers without any solution for a product that you are still selling....
- SnorkyDec 23, 2020Star
After numerous disconnects and instability, and terrible support, I sold mine on ebay (took a loss), bough TP-Link Deco and it is faster, more reliable, sweet! I am never buying Netgear again!
- tommyjliFeb 04, 2021Aspirant
Agree with all of the above.
I finally sold off my MK62 system using wired backhaul which had constant stability issues. Worst WIFI system i've ever had. After some friendly (but not useful) support tickets, I decided to sell it off (sorry to the new buyer) and bought 2x Asus AX-82U routers in AiMesh. First time using Asus, the AiMesh setup is super easy (again wired backhaul). It's been 2 months (since xmas) with zero stability issues.
Honestly this Netgear system is a waste of time. I hope their higher end systems are better, but I thought it would be a simple AP system with wired mesh (have no false hope that wireless back haul on a triband would be high performance enough). - Bdejong11129Feb 18, 2021AspirantHow can they continue to sell this? I bought it on an impulse at Costco this week and its worse than dial up. We are finding mobile Hotspot better. So long netgear, returning this and moving on to any one but you!
- mrbeamsFeb 21, 2021Guide
ALL, I have ben working with NetGear Support for the past 6 months with inproving success. I have been through severa Beta software trials and provided feedback at each level. I was in the middle of trying to recreate the issue and a Beta version but was not having success. The latest production release came out, I upgraded and again with this version I cannot create the issue. My throughput is still very high. The only devices that are still misbehaving are a pair of older Samsung SmartCam's that I still use for internal monitoring of my pets. These are old and I will replace in the next year. No vulnerability updates from the vendor on the cameras. Other monitoring cameras would well. I believe this continuously try to reconnect to reach back to Samsung via UPNP, which I have blocks. I utilze the VPN features on the router to connect back into my network to monitor Blue Iris when I am out. Much safer solution than broadcasting UPNP Video on the internet. I worked extensively with NetGear Support during this period and would like to give a shout out to Eahl in the suport team. He was very helpful, thorough, and followed up better than most companies I deal with.
Thanks
Christian_R thanks for the connection to the support team after my initial post. I did subscribe to Pro Support and definately worth it.
