bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
tm1900
Sep 12, 2020Aspirant
Hi Mike, what app are you using to find out what channels your neighbors are using?
Thanks,
D
Thanks,
D
Retired_Member
Sep 17, 2020Hello @Christian_R, do we have any update about this? any kind of new beta firmware?
I bought this on june 30th and im still unable to use it...
3 different firmwares...
1 beta firmware...
2 support cases...
and yet we are like the beginning...
- BourbonOnRocksSep 21, 2020Aspirant
Been dealing with this 1.5 months and finally was given support. Change 2.4ghz from Auto to channel 09. Change 5ghz to channel 157. Problem solved assuming you are running the latest firmware.
- reverendoandreSep 21, 2020Aspirant
keeping my fingers crossed here
