bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
RobotMan_
Nov 26, 2020Aspirant
I purchased the MR60 mesh at costco. Lost connection 2 or 3 times per day. I am connected to a cable modem which has built in wifi, Modem/wifi combo via cable that came with unit. I disabled the wifi on the cable modem and I have not lost connection in 3 days. Just running the wifi on the MR60 Mesh. I followed the setup wizard and set the SSID at password to match the current wifi of the modem as instructed in the setup instructions. Is it possible the wifi on the MR60 was interfering with the wifi broadcast of the cable modem/wifi combo unit?
artenais82x
Nov 30, 2020Aspirant
Hi everyone.
Do not know if it may help you, but setting manual bands and disabling "20/40 Mhz coexistence" helped in may case ( but I only had a single device dropping like crazy, so it may not apply for you ).
Thank you.
