bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
Cincykid
Dec 24, 2020Initiate
Constant drops. Have tried everything. Returned my new modem thinking it was related but as a test, now have Xfinity modem and still having issues connecting. Think I am taking this back as well.
- Retired_MemberFeb 03, 2021
Hello all,
I just wanted to tell you that last firmware seems to be more stable. However im using only the router (without the satelite).
But also, i want to share my final answer before i close the support case:Hello XXXX!
Im testing this one since saturday.
Is much more stable than before. However my computer got kicked from the network without any reason.
Although it happened once.
I have to update the satellite.
However i will not keep this device as is still not good enough...
Really a lot of missing options/configurations.
I cannot setup specific SSID for specific band, mobile devices are jumping from one band to the other...
I already went for another solution, much more flexible and stable than this one.
So, thanks for your support... this is my last repply as i will never use a netgear product again, and of course, i will never recommend it.
