bjhoag
Apr 15, 2020Star
Nighthawk Mesh Wifi 6 Router MR60 losing connection to 2.4 devices
I have a Nighthawk Mesh MR60 with the Satelite. About once a day, it loses connection to all the 2.4 devices on my network. It remains connected to the 5.0 devices. I have to reboot the router and...
mandolp
May 07, 2020Initiate
I am haing the same issue. I found that if I reboot the satalite it fixes the issue. That way I can still use the main router until the satalite is up an running. It seems that the older devices are the ones having issues connecting (ipads & chromebooks)
szuppo
Aug 24, 2021Tutor
Should have saved your money. I’ll never touch Neatgear Crap again. Two faulty MS 60 satellites that were replaced and today my MR60 is dead after attempting an update. Netgear response: too bad, you’ll have to buy a be Router. Sure, no problem. Won’t be any **bleep** you manufacture though.
