rbalcon
Jul 25, 2021Tutor
Nighthawk Mesh WiFi 6 system cannot add satellite on wireless network
I bought a NETGEAR - Nighthawk MK63 AX1800 Wi-Fi 6 Mesh Router with Two Satellite Extenders. I am trying to add another satelite but cannot add wireless but only using a cable to the router. If I syn...
- Jul 25, 2021
plemans seems the fix is to use the synch button using the router app "Add Netgear Satelite" feature and then press the synch button on the satelite harware, at the same time, the satelite then connects and the light turns blue, eventutaly. The only issue is if you unplug the satelite you have to setup the synching again, it wont reconnect automatically.
rbalcon
Jul 25, 2021Tutor
plemans same result, will only connect when the satelite is wired. I get a red light when I try synching the satelite.
rbalcon
Jul 25, 2021Tutor
plemans got it working now, after reseting it, moving it away form the router and resynching several times, thx
- rbalconJul 25, 2021Tutor
- plemansJul 26, 2021Guru - Experienced User
eitherway, glad to hear you got it working!
If you mark your answer as solved, it might help the next person with that issue (since there's so few on here helping)
