Alevine1nc
Mar 31, 2021Tutor
Nighthawk Mesh WiFi 6 system MK63, AX1800 Satellite causing network loss over wifi
Nighthawk Mesh WiFi 6 system MK63, AX1800 I’ve had the system for about a week. Tonight we discovered that throughout was down to < 1 mbps using google speed test. My son is a gamer and he brought it...
- Apr 03, 2021good luck with it! I've read good things about googles mesh. I haven't used it though
Alevine1nc
Apr 01, 2021Tutor
Spoke too soon. As soon as we settle down to watch a movie, my son comes to me and says he’s getting > 1mbps in his room. Sure enough it’s the same story as last night. I’m really done with this system now. If I was getting average 50 mbps everywhere I’d be satisfied. But going from +100 to -10 with no rhyme or reason really tells me this system is crap. Wife wants me to exchange it at Costco but this shouldn’t be happening. If it’s not bad hardware it’s a crap system.
Yes I did resync the satellites with the router.
Apr 01, 2021Guru - Experienced User
Do you have the 2 satellite system?
Is it only the 1 satellite causing issues?
Did you try factory resetting that satellite?
You could also try reloading the firmware to the satellite, then factory resetting and reinstalling. If its an issue of corrupt firmware on it, this could overwrite it.
- Alevine1ncApr 03, 2021TutorI punted and returned this garbage system. Picked up a google mesh system and will see how it goes. If that doesn’t work I will go to the orbi for more cost.
- plemansApr 03, 2021Guru - Experienced Usergood luck with it! I've read good things about googles mesh. I haven't used it though
