GinA28
Jan 02, 2025Aspirant
Nighthawk Mesh WiFi 6 System Not Delivering Speeds
I have been having trouble with my mesh system. When I run the internet speed on the nighthawk app, it states that is is pulling 607.02Mbps but when I run speed tests on any of the devices close to ...
GinA28
have the MR60 Router and 1 MR60 Satellite. it is using firmware version 1.1.7.134. I checked for updates to the firmware and it said it was up to date.
I'm not that techie to understand a lot of the other settings, and I understand I will get less speeds through wifi than I do directly connected to the router, but to go from 600 down to 200 when the only thing actively running is one computer and the TV seems a bit much. My old Orbi didn't drop that much. I ran the speedtest dot net on a laptop, a desktop, a cell phone, and a tablet and they were all pretty much in the 200-220 download speed range.
I don't know how to do much else without direction, unfortunately.
michaelkenward
Jan 03, 2025Guru - Experienced User
Indeed. You should get better than that.
What modem/gateway/optical network termination (ONT) sites between the MR60 and the Internet?
If those are connected by wifi, that throws in another complication. Perhaps a reset is worth trying.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. It is also the first thing that Netgear support will recommend.
Just another user with time on their hands.
- GinA28Jan 03, 2025Aspirant
Yeah unfortunately everything in my house is run by wifi lately. I will try the factory reset. Hey that works sometimes 🙂 Thank you!
