sg-
May 25, 2020Aspirant
Nighthawk mesh wifi 6
I recently purchased a nighthawk. In order to work as extended it can be connected without the ethernet cable or I have to connected to my router
May 26, 2020Guru - Experienced User
We need some details.
What device did you purchase? nighthawk isn't a model, its brand.
what router are you connecting it to?
you can go to netgear.com/support/ and type in your model number. It'll take you to manuals, firmware, and guides that can help install and setup your new device.
