sg-
May 25, 2020Aspirant
Nighthawk mesh wifi 6
I recently purchased a nighthawk. In order to work as extended it can be connected without the ethernet cable or I have to connected to my router
May 26, 2020Guru - Experienced User
We need some details.
What device did you purchase? nighthawk isn't a model, its brand.
what router are you connecting it to?
you can go to netgear.com/support/ and type in your model number. It'll take you to manuals, firmware, and guides that can help install and setup your new device.
sg-
May 26, 2020Aspirant
Model #- MK63-100NAS
- plemansMay 27, 2020Guru - Experienced User
Hooking it to what?
And what are you attempting to do?
You're giving me very minimal info. I'm not there to see what you're doing, what you're attempting, or even what results you're getting. If you want help, you need to help us to help you.
