dressage710's avatar
dressage710
Nighthawk Mesh Wifi Ethernet
Have a Xfinity router in a small room in our barn, the Nighthawk router is plugged into Xfinity and the satellite is in our indoor arena, it goes in and out a lot. Amer light to Blue light we have a ...
  • plemans's avatar
    Aug 31, 2022
    200ft is to far for router to satellite.
    Yes you can certainly move the router closer to the satellite with the cat cable. You can also hardwire in the the satellite if you'd like and use it as a wired backhaul
    In terms of the settings between the gateway and router. Its more what you prefer. There isn't really a better mode. Its more what works better for your setup. If you move the primary router and want to use the xfinity router's wifi as well, you could set the xfinity up with its wifi on a different channel and ssid. Then just put the netgear in access point mode. That'd allow you to use both
