dressage710
Aug 28, 2022Aspirant
Nighthawk Mesh Wifi Ethernet
Have a Xfinity router in a small room in our barn, the Nighthawk router is plugged into Xfinity and the satellite is in our indoor arena, it goes in and out a lot. Amer light to Blue light we have a ...
- Aug 31, 2022
200ft is to far for router to satellite.
Yes you can certainly move the router closer to the satellite with the cat cable. You can also hardwire in the the satellite if you'd like and use it as a wired backhaul
In terms of the settings between the gateway and router. Its more what you prefer. There isn't really a better mode. Its more what works better for your setup. If you move the primary router and want to use the xfinity router's wifi as well, you could set the xfinity up with its wifi on a different channel and ssid. Then just put the netgear in access point mode. That'd allow you to use both
dressage710
Aug 30, 2022Aspirant
1. what mesh system did you buy? (model) Mesh WiFi 6 MR60
2. the satellite is 150-200 ft from the router? That'd be why its going in and out a lot. I measure last night and the satellite over 200 ft away
3. you can move the router with a ethernet cable. You can run up to 300ft with a decent quality ethernet cable That is my original question if I get a Cat8 ethernet cable and move the MR60 router closer to the satellite?
4. You have an xfinity router? If so, is the netgear in access point mode or the xfinity in modem only/passthrough mode? Or you're in a double nat. I didn't set it up so I would have to ask, it is an xfinity router which mode is better? Thanks
Aug 31, 2022Guru - Experienced User
- dressage710Aug 31, 2022Aspirant
THANK YOU so much for your help!!!!!!!! One more question what Cat ethernet should I use move the Nighthawk router closer to the satellite Cat 6, 7, 8...I need about a 100ft cable? Thx
- plemansSep 01, 2022Guru - Experienced User
I would just get a decent quality cat 6 cable.
- dressage710Sep 01, 2022Aspirant
Thank you!!!!!!!!!!!!!!!
