peteelliot2012's avatar
Dec 19, 2020
Nighthawk mesh won't connect to internet
Hi all, I just purchased the nighthawk mesh wifi 6 system (MK63) and can't get it to receive an internet connection from my modem (vendor owned modem from Spectrum). I spoke with a tech at the ISP (...
  • plemans's avatar
    Dec 20, 2020
    start with factory resetting the modem and router. Push and hold reset for 7-15 seconds while they're powered on. Then, once reset, power off the motorola and the netgear. disconnect all ethernet cables from both and the coax from the modem.
    Wait a couple minutes.
    Then connect coax back to the modem and then power it on. wait a few minutes for it to fully boot.
    then connect the modem to the routers wan port.
    Power the router on. wait a few minutes.
    Attempt setup.
