Lifeisgood76
Nov 17, 2021Aspirant
Nighthawk mesh
White light constantly blinks like it’s rebooting….
Nov 17, 2021Guru - Experienced User
What white light?
did you look at the manual?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- Lifeisgood76Nov 17, 2021AspirantThe light on the front of the modem….. yes I’ve read just about everything….
- plemansNov 17, 2021Guru - Experienced User
What actual model version is it?
Are you having issue?
What modem/gateway is it connected to?
what firmware is on it?
