wildoaksman
Jun 06, 2020Aspirant
NightHawk MeshWiFi 6 system
Can the Nighthawk mesh 6 system be connected to sierra wireless Unite- 9859 WiFi Broadband or the Nighthawk M1?
Jun 09, 2020Guru - Experienced User
The M1 has an ethernet port you can use to connect. But you need to make sure either the M1 is in passthrough mode or the Mesh system in AP (access point) mode to prevent a double nat.
- wildoaksmanJul 05, 2020Aspirant
How do I do that
- plemansJul 06, 2020Guru - Experienced User
Do what specifically? And for what device?
You can go to netgear.com/support/ and type in the model number. it has manuals, guides, firmware, etc.
