Potzo
Jul 17, 2020Initiate
Nighthawk MK62 - Port forward list empty
Model: MK62 As title says, custom added ports under "Port Forwarding / Port Triggering" are not showing up. Therefore, I can't even delete or edit the added items anymore. But if I try to ad...
koko2870
Aug 14, 2020Tutor
Thanks for the workaround but at this point I'm about to give up on this mesh system and go with another company. This is the second time that an update for this mesh system has broken something or wiped out my setup. Not to mention that this product seems to have some very serious connectivity issues (dropping internet connections, etc). Not very well tested before release. maybe they are just putting all the good stuff into Orbi.
Netgear used to have pretty reliable products but lately the stuff I've bought (extenders, etc.) have had lots of issues.
knightz01
Aug 14, 2020Apprentice
Tech support are now live on youtube https://www.youtube.com/watch?v=s5SbPo5tbLg
I use firmware Version 1.0.4.98 with nil dropouts. Kev
koko2870 wrote:Thanks for the workaround but at this point I'm about to give up on this mesh system and go with another company. This is the second time that an update for this mesh system has broken something or wiped out my setup. Not to mention that this product seems to have some very serious connectivity issues (dropping internet connections, etc). Not very well tested before release. maybe they are just putting all the good stuff into Orbi.
- koko2870Aug 15, 2020Tutor
Reverted back to 1.0.4.98 but still no port fwd settings showing & can't re-add them because it says it already exists. don't want to reset my network (again) and recreate all my settings. I already had to do it with the last firmware upgrade that wiped it out.
This system isn't worth the hassles. Looking for a replacement.
Thanks for the suggestion though.
