Diablodar's avatar
Diablodar
Nighthawk MK62 Firmware v1.0.5.102 Issue
I updated my MR60/MS60 Mesh router and satellite to the current firmware version 1.0.5.102 found on netgear's support portal, and found after doing so my network speeds on my spectrum gigabit network droped to 250mbs. I restored the firmware to a previous version of v1.0.4.98 and my speeds are back to normal at 940mbs. I went back and forth twice between the two versions just to be sure.  Trying to get this to support, but can't figure out how.
  • Diablodar's avatar
    Diablodar
    Aug 12, 2020
    Christian,
    Thank you it is greatly appreciated.  Looks like the issue was fixed with v1.0.6.102 recently released. The router/satellites are now working as expected.
    Thank you.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Diablodar,
    Thanks for your feedback. I'll have the info forwarded to our product teams.
    Thanks,
    Christian
      Diablodar
      Christian,
      Thank you.
        Christian_R
        Hi Diablodar,
        Glad to hear! Thanks for confirming!
        Christian
