gabry2404
May 31, 2022Aspirant
NightHawk MK63: adding satellites
Hello everybody. I go straight to the matter: I had a MK63 nighthawk system whose main router broke down due to a power surge. The two satellites, however, should not have suffered damage. So I bou...
May 31, 2022Guru - Experienced User
try hardwiring the old satellites into the new router and syncing them that route. after they sync, you should be able to disconnect the ethernet wire
- gabry2404Jun 02, 2022Aspirant
First of all, thank you for your reply & time.I hardwired , as suggested, the old satellite into the new router, but it did NOT work; the led of the satellite, after blinking white, remained red.
I'm more than sure that it is possible to add new satellites (up to 4) but I start thinking they must be kind of "vergin" (not belonging to an old kit). These old ones have on their back the SSID of the old router. This may explain why they don't "talk" with the new router.
However, any other piece of advice?
- plemansJun 02, 2022Guru - Experienced User
If you hardwire into the satellite, you should be able to access it at 192.168.1.250
make sure its running the same version of firmware thats on the router (but the satellite version)
- PalicoMeowsterSep 01, 2022Aspirant
Hello Gabriel,
Sorry for replying to the old thread, but I'm wondering if you have resolved the issue with adding the two satellites into the new mesh?
I recently purchase a satellite off Ebay from someone who has broken router. The satellite was able to connect into the mesh. When I first added the 3rd satellite, it connected to one of the existing satellite, however, I had to do maintenance and the whole mesh needed to go offline for a bit. Once everything is back online, the additional satellite is no longer want to connect to the existing satellite and connect directly to router.
This is where the problem started to occur. I found that one of the satellite kept disconnecting and reconnecting to the router. Later I found out that they recommended to use wired backhaul or daisy chain for additional satellite after 2 satellites. Though they put that on knowledge base, they should also add this information on their product pages and part of their retail description on any other retailers.
I haven't tested with wire backhaul yet as that is not what I want to do. I plan to run cable through my attic later in the year once the weather is much cooler than now. I lived in southern states so it is still very hot in August.
Best regards
