Malsford88
Feb 08, 2021Aspirant
Nighthawk MK63 best modem
Hi Model no. MK63-100UKS Just bought the Nighthawk MK63 Router but comes without a Modem, please can someone recommend a VDSL modem that supports MER capability (option 60/61). Thanks
Starzoneca
Feb 08, 2021Tutor
Malsford88 wrote:Hi
Thanks
If You already have a VDSL modem/router combo, I would suggest you just turn off the router function off and only use modem function. Thats said you always check with your ISP if they were the one who supplied your current modem/router. Please note that NETGEAR does not recommend setting your cable modem/routers to modem only. This mode should be used under special circumstances only.
