Chucksadoy
Sep 26, 2021Aspirant
Nighthawk MK63 Mesh Newbie
Can anyone let me know if I need to have only the new mesh system connected to my internet main router when I attempt to setup the new system? Or will my Motorola MG7550 dual channel main router allo...
- Oct 14, 2021
Thanks for the reference to the manual. Unfortunately like all large manuals it assumes understanding of someone with a little network experience other than just plug-and-play. I will have to research all the setting terms references so I can interpret how to do something that seems to be simple like setting the mesh router to be an access point.
My hope had been that I might find someone interested in offering a helping hand to walk through some of the processes of setting up the mesh and then incorporating it into my existing internet connection. Even a few references to helpful videos or publications might have been nice. Sorry to whine, but I often encounter this when more elite groups feel it a bother that rank amateurs seek their help. Even if that weren't the case, it sure feels like it.
I do appreciate the responses received, but I think using this kind of community is a little over my head.
Sep 27, 2021Guru - Experienced User
You can use both systems but you need to do a little configuring to get it working properly together.
having 2 router systems causes a double nat.
if you're wanting to use both systems you have 2 options.
1. put the netgears IP address into the Motorola's DMZ
2. put the netgear into access point mode.
