lastboy1228
Mar 11, 2023Aspirant
nighthawk MK63 vlan group
V1.1.7.134_2.0.65 Does it only bridge MR60 device's ethernet port1 to wan port, not work for MS60 device's ethernet port1? Can I have a wireless bridge from nighthawk MK63 suit?
Mar 11, 2023Guru - Experienced User
Like michaelkenward says, your post doesn't make much sense.
Its doesn't really tell us whats going on or what you're trying to achieve.
But keep in mind, the vlan on the consumer side gear is basically for IPTV usage and specific markers certain ISP's need.
Its not the same as the business class gear.
https://kb.netgear.com/25724/VLAN-tagging-setup-for-Nighthawk-router
