mkiiina
Nov 02, 2021Tutor
Nighthawk MK83 No Internet, Intranet works fine - Support is terrible
Have had the MK83 since 04/2021 and up until the last month or so, it had be relatively trouble free. To preface this, I would consider myself a prosumer and have set up/maintained several above ave...
- Nov 09, 2021
Finally got an RMA but took 6 hrs total and threatening to involve the state consumer protection board and that I had been recording all the calls (1 party state). Netgear makes it very difficult to actually get an RMA and for a premium product I expected much better. Will be selling this once the replacement shows up. Luckily when I was getting a new router I was able to sway someone from going down the path I did and talked them into an Asus router instead of a netgear product.
mkiiina
Nov 03, 2021Tutor
Rolled back the firmware to 1.1.5.4 and briefly had internet but a power cycle later and no internet again.
Still no response from "Customer Care".
Nov 03, 2021Guru - Experienced User
- mkiiinaNov 03, 2021Tutor
Arris TM1602
ISP is Spectrum
- FURRYe38Nov 03, 2021Guru - Experienced User
Have you powered OFF the modem AND MR for 1 full minute or more then back ON with the modem and them MR?
The TM model modem is getting to be a bit long in the pants and IMO was never a good modem.
Also check the LAN cable between the modem and MR. CAT6 lan cabling is recommended.
Does the the MR give any inidication on the front LED or on the MRs web page when you can't access the internet all all with a wired PC?
Can you still access the MRs web page when this happens at 192.168.1.1?- mkiiinaNov 03, 2021Tutor
I have noticed that the modem takes longer to boot so take that into account when doing power cycles.
Cables are in good working order (this can be validated in that they are currently working with my old router just fine).
MR80 can be accessed from 192.168.1.1 when using an ethernet connection to the router (have not tested with a wifi connection but assume it would be accessable there as well). It correctly assigns local IPs to connected devices (will register 30+ devices and the 2 satellites).
Connecting via 192.168.1.1 and looking on the main page it shows Internet Offline. When you scroll down to the details it does list a valid IP from my ISP (which is really odd) but no ability to actually get out anywhere.
