Hammer5000
Jun 02, 2021Aspirant
Nighthawk MR 60 Mesh Satellite Connection issues
I just purchased and set up last night, one router and two satellites. Everything seems to be working properly, except nothing is connecting to the satellites, even my Amazon Fire Stick which is in t...
Hammer5000
Jun 03, 2021Aspirant
The satellite in the room with the Fire Stick is less than 30 feet, more like 18 feet from the router. Sounds like the satellites only engage if the router signal is not as strong as the satellite?
I bought the mesh system because the Fire Stick occasionally struggled with my old router. Sounds like I don't need the mesh system. My house is only 1950 sq ft.
Jun 03, 2021Guru - Experienced User
It still can help with coverage having the satellites but just make sure they're far enough apart or devices don't roam as you'd expect.
