MontanaJack26
Feb 19, 2022Aspirant
Nighthawk MR 60
Router has 2.4 ghz and 5ghz. Smart plugs sync on 2.4 only. I can get into router via 192.168.1.1 but do not know how to turn off 5ghz to allow plugs to sync up
Feb 19, 2022Guru - Experienced User
You can't turn off the 5ghz.
The problem is poor coding on the plugs. It shouldn't matter for setup if you're on the 2.4ghz or the 5ghz but for poorly coded devices it does. If you can connect your phone/tablet to the 2.4ghz you should be able to set it up
MontanaJack26
Thanks
The plugs can be synced up on 2.4. I will try the phone/tablet
