radam
Nov 28, 2022Aspirant
Nighthawk MR60 - overloaded and then internet disconnected if using WiFi
Hello, i was using MR60 without any problems for more than 2 years. Now after every 4-24 hours I need to reboot to connect to internet. With used WiFi, it somehow freezes (data not working) and disc...
Nov 28, 2022Guru - Experienced User
You have another router? or a gateway with its own routing capability?
What happens if you use that and put the MR60 in AP (access point) mode
- radamNov 28, 2022Aspirant
Yes, I have one. Official from my internet provider (Zyxel with very bad WiFi coverage).
My plan is to try it exactly like you suggest. Will let you know.
But it sound little bit strange setup after 2 years of no problem usage đ
