NotPleasedatall's avatar
Nov 18, 2020
Nighthawk MR60- No 5G
Used to have 5G, and then it disappeared a few months ago.  No device in the house sees 5G as an option now.  Have tried rebooting and erasing settings and reconfiguring.  Any ideas?
  • plemans's avatar
    The MR60 is a mesh system. Meaning it combines the 2.4ghz and 5ghz signals into 1 ssid. And then devices band steer between the 2 bands as needed.
  • I have the same issue on a R7000P router. My 5 GHz wifi network no longer shows up on any of my devices. Checked on the router portal and it looks like it's stopped for some reason even though it's enabled in Advnaced > Advanced Settings > Wireless settings. I also did a reset to factory default settings as well as upgrade to the most recent firmware but still the same thing. I'm curious to find what other things I could try..
    • plemans's avatar
      The R7000P isn't the same as the MR60.
      Please start your own thread.
      mshakr
