Lloydian's avatar
Lloydian
Follower
Dec 03, 2021
Nighthawk MR60 and Remote Desktop Connection
I've seen multiple threads about this subject, but none actually solving it. Here's the situation. We are using this mesh system to replace the ASUS router that was in place previously. With the ASUS router, we had no issues with remotely connecting, but we can't with this router. I can't decide if I've configured it incorrectly or if the built in firewall is blocking everything.
The two computers are listening on ports 3385 and 3386 respectively. Within the office they have static IP addresses. I've set up custom port forwarding services for both of them on the router with the same internal and external port, and identifying the correct internal IP addresses.
Does a firewall block traffic on those ports? If so, how do I turn it off? I don't see anything that addresses this. On WAN setup, I see "Disable Port Scan and DoS Protection," but checking that box did not solve the problem. Should I have used a different port forwarding method?
I'd like to use these mesh routers, but if they simply don't work, I can't.
1 Reply
