krommetje
Dec 07, 2020Tutor
Nighthawk MR60 cannot download vpn config files
Hi all, I just bought a netgear MR60 with firmware V1.0.6.102_2.0.45 and want to use the vpn, for that I need to download the ovpn config files but that is not possible.... I click on the button...
michaelkenward
Dec 08, 2020Guru - Experienced User
I assume that you have read the VPN bit in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
There you will find things like this:
- krommetjeDec 08, 2020TutorYou mean: "7. Click the For non-Windows button to download the OpenVPN configuration files." On page 107 of the manual? the concept of Read the **bleep**ing Manual is very well known to me.... If you don't have anything to add then don't add at All...
STFU- michaelkenwardDec 08, 2020Guru - Experienced User
krommetje wrote:
On page 107 of the manual? the concept of Read the **bleep**ing Manual is very well known to me....It didn't show in your message.
Given you failure to find the right place to ask about your device, I think I can be forgiven for assuming that attention to detail is not one of your strengths.
Are you also too proud to search the community for messages that might be related to your problem?
You may have a hard time here if throwing around insults is your idea of a reasonable response to people who offer help.
I am not going to litter this community any further, just stay on your little pedestal...
Moderator! you can close this thread
