krommetje
Dec 07, 2020Tutor
Nighthawk MR60 cannot download vpn config files
Hi all, I just bought a netgear MR60 with firmware V1.0.6.102_2.0.45 and want to use the vpn, for that I need to download the ovpn config files but that is not possible.... I click on the button...
krommetje
Dec 08, 2020Tutor
You mean: "7. Click the For non-Windows button to download the OpenVPN configuration files." On page 107 of the manual? the concept of Read the **bleep**ing Manual is very well known to me.... If you don't have anything to add then don't add at All...
STFU
STFU
michaelkenward
Dec 08, 2020Guru - Experienced User
It didn't show in your message.
Given you failure to find the right place to ask about your device, I think I can be forgiven for assuming that attention to detail is not one of your strengths.
Are you also too proud to search the community for messages that might be related to your problem?
You may have a hard time here if throwing around insults is your idea of a reasonable response to people who offer help.
- krommetjeDec 08, 2020Tutor
I am not going to litter this community any further, just stay on your little pedestal...
Moderator! you can close this thread
