krommetje
Dec 07, 2020Tutor
Nighthawk MR60 cannot download vpn config files
Hi all, I just bought a netgear MR60 with firmware V1.0.6.102_2.0.45 and want to use the vpn, for that I need to download the ovpn config files but that is not possible.... I click on the button...
jzlg
Apr 28, 2021Initiate
Same problem here,
After following all steps in the manual, not able to download the config files needed to setup the VPN connection.
Tried different devices, and different browsers.
DDNS is already enabled and set up since this is required for the MR60 VPN.
Also the button checks if DDNS is enabled when you click it.
Still, nothing happens if i press the button.
Anyone been able to come up with a solution for this problem?
