kevinmjones
Jun 11, 2023Aspirant
Nighthawk MR60 DHCP Issues
PRODUCT: Nighthawk MR60 Firmware Version V1.1.7.134_2.0.65 I have struggled with this product for over a year now. The system is so fragile that any change such as , a new device connects, you ...
Jun 11, 2023Guru - Experienced User
How are you updating the system? Manually or thru Auto Update?
Manually is recommended with downloading the FW files and sending to the MS web page FIRST, then sending to the MR lastly. After the system as processed the files and is back to ready. I recommend factory resetting the entire system and setting up from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you have all connected?
Be sure that Apple and Android devices have any Mac Address randomizers disabled while at home:
How many MS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
I've not seen this behavior with my MK63 system...
- kevinmjonesOct 24, 2023Aspirant
I added 2 more devices to my network this weekend and it took down most of my network again , until I went in and manually set IP addresses on the client and then set a static ip address in the router for the device.....
My dhcp range is 100-200 and my assigned devices are all under the 100 range.
- FURRYe38Oct 24, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What devices do you have all connected?
What is the distance between the router and ‌‌ satellite(s)? 30 feet or more is recommended in between MR‌‌ and MS‌‌️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products ‌‌I've not seen this behavior with my MK63 system...
You should only set a static IP address ON the devices that's out side of the MRs DHCP IP address pool and not with in it. If you set the device to Dynamic IP address configuration, then set a IP address RESERVATION with the MRs DHCP IP address pool then.
