luga13
Jan 30, 2024Guide
Nighthawk MR60 dropping internet speed
my Night Hawk MR60 with two satellites was behaving properly giving me as expected internet speeds, however not sure when it happened but definitely between October 2023 and January 2024, the maximum...
luga13
Jan 31, 2024Guide
thanks, i read it through but what i am supposed to be looking at, this is how it looks
System Up Time 13 days 19:37:29
| Port | Status | TxPkts | RxPkts | Collisions | Tx B/s | Rx B/s | Up Time |
| WAN | 100M/Full | 15964317 | 83114279 | 0 | 59325 | 241421 | 2 days 09:57:49 |
| LAN1 | 100M/Full | 2741630 | 356452 | 0 | 460 | 93 | 13 days 19:34:16 |
| 2.4G WLAN b/g/n/ax | 600M | 3982852 | 1745548 | 0 | 923 | 715 | 13 days 19:37:29 |
| 5G WLAN a/n/ac/ax | 1200M | 30977805 | 14331047 | 0 | 72744 | 2690 | 13 days 19:37:29 |
| WLAN Backhaul | 1200M | 2318320 | 14 | 0 | 327 | 0 | 13 days 19:37:29 |
Jan 31, 2024Guru - Experienced User
so its only connecting at 100mbps speeds.
Try replacing the cable between the modem and the router. Make sure to use a good quality cat 5e or cat 6 cable.
Whats connected the lan port as its only connect at 100mbps speeds too.
- luga13Jan 31, 2024Guide
thank you, I have replaced the cable for a brand new one provided with the new Modem...I ran the stats and still shows the 100..is there another way to change the settings?
