luga13
Jan 30, 2024Guide
Nighthawk MR60 dropping internet speed
my Night Hawk MR60 with two satellites was behaving properly giving me as expected internet speeds, however not sure when it happened but definitely between October 2023 and January 2024, the maximum...
Feb 01, 2024Guru - Experienced User
Last resort, do a 30-30-30 reset on the MR with out anything connected to it. After the front LED is blinking WHITE or goes to solid AMBER, connect up your one wired PC to the WAN port on the MR60, not the LAN port. Look at your PCs networking status and find the connection/speed rate of the ethernet adapter on the PC. Let us know if it's 100 or 1000Mpbs here.
Did you try a wan- lan test and then check those port statistics when it's hooked up like this? Sorry on Mobile so didn't see if that was suggested.
https://kb.netgear.com/28408/An-Internet-or-LAN-port-isn-t-working-correctly-on-my-router-How-do-I-perform-a-loopback-test-to-check-the-port
