mcdsinfo1944's avatar
mcdsinfo1944
Nighthawk MR60 MESH NETWORK
How do I separate 2.4GHz and 5GHz SSIDs on my Nighthawk Tri-bank Mesh WiFi 6 product?  Do I need to upgrade to MR80 or MS80 product?
  • Thanks. That's what I understood after reading the "Can I create separate 2.4........article.  Already ordered the upgrade.
    Reason:  "You can connect slower or older devices to the 2.4GHz band. Since these devices don’t need a lot of bandwidth, the speed and performance of your 5GHz band is reserved for your high-speed devices." Some or our Smart devices would not connect to the MR60 product.
    • mcdsinfo1944's avatar
      mcdsinfo1944
      • plemans's avatar
        You should still be able to connect your Iot 2.4ghz devices to the mr60.
        It can sometimes be a bit more of a challenge as many IoT device makers are lazy and code poorly but it can be done.
