Poison_6022
Jan 10, 2022Tutor
Nighthawk MR60 Mesh Router Bricked by Firmware Update
This is a report that I apparently posted in the wrong Netgear Community forum earlier this morning. Currently I have a mesh WiFi system in my house, based on the Nighthawk MR60 router, with two ...
Jan 10, 2022Guru - Experienced User
I recommend you try using a Windows PC platform to see if you can get TFTP or nmrpflash to work properly since these are Windows based platform applications.
I would ask NG support about RMA options that maybe available.
Please refer to this FW update method to install FW manually on the MS first the MR lastly.
