Boby32x's avatar
Boby32x
Nighthawk mr60 mesh system not connecting to security/vice-versa
Hello, I have a lorex security system that I just installed, as well as this MR60 mesh network router and I cannot get it to connect, no matter what I have tried. I also have a nighthawk ax12 (rax120...
  • Boby32x's avatar
    Boby32x
    Nov 10, 2023
    Turns out that the ethernet cable that came with the MR60 router was bad right out of the box. I replaced it and now everything (including both switches and even the security system) is working.
