Retired_Member
Jan 10, 2023Nighthawk MR60 Mesh Wifi routers/satelites not working normally with any update after V1.0.6.116
hello , im using Nighthawk MR60 Mesh Wifi routers/satelites from two yers , my Nighthawk not working normally with any version after V1.0.6.116 , . Devices not connected to wifi after update . or c...
Jan 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Please try v.134:
Manually download the files and use a wired PC and web browser to update the MS first then the MR lastly using there web pages. After FW is loaded and the system is back to ready, power OFF then back ON then factory reset the MR and setup from scratch.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Retired_Member
Jan 10, 2023tried Version 1.1.7.134 same issue
When downgraded version to V1.0.6.116 and it works perfectly
- FURRYe38Jan 10, 2023Guru - Experienced User
Please give more details of "not working normally with any update after V1.0.6.116"
What are you seeing and explain what is happening.
- Retired_MemberJan 10, 2023
I have 20 wifi devices , after the update some devices not connect to wifi ( amazon dot , xiaomi ceiling light ) ,
some devices ( iPhone , MacBook , Samsung tv ) connect few minutes and return to disconnect
The device keeps trying to connect to the network but does not connect
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.️
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡What channels are you using?
Any Wifi Neighbors near by? If so, how many?How is advanced wifi configured on the MR?
Are you factory resetting the system and setting up from scratch after last FW update attempt?
- Retired_MemberApr 05, 2023I am facing the same problem, and it has not been resolved yet
