Bglover
Apr 01, 2022Aspirant
Nighthawk MR60 needs to be factory reset every day
When I awake in the morning every device I have can't connect to my router, so I have to go through the pain of manually resetting the router to default, letting it start up as the default SSID, then...
Apr 01, 2022Guru - Experienced User
what hiltron modem? they make a lot
Have you tried reinstalling the firmware to the satellites and then the router? Maybe something is corrupt in the firmware
Then do the factory reset/reinstall.
Bglover
EN2251 is the Hiltron Model. Do you have a link to the instruction to do what you're talking about with the firmware? I truly appreciate your help with this.
