tramperB
Nov 14, 2022Guide
NightHawk MR60 resets VPN service after reboot
Hi, hoping someone can assist with this one. I've enabled (and applied) the VPN sevice on my NightHawk MR60 (FW: V1.1.7.132_2.0.64 which is the current version) and all works fine. The problem i...
- Nov 15, 2022
OK, managed to have an hour with the router.
First, I enabled & set up a bogus DDNS. Rebooted the router and both DDNS & VPN services became disabled (ie issue still occurring).
So, I did a hard reset (button push) and set up the router again. Then set VPN service to enabled & applied. Re-booted the router and ... VPN service remained enabled.
So, restored the previous backed up settings and rebooted the router. VPN service remained enabled.
So, a hard factory reset fixed the issue (thanks for the suggestion). I'm short of time now so I have not tested if the soft factory reset now works as well - I presume that, too, is fixed.
tramperB
Nov 15, 2022Guide
Only difference is that I don't enable DDNS - I have a static IP. Can you try it like that?
(ie enable VPN service, apply, acknowledge the DDNS pop up but don't set DDNS. Then reboot.
(edit: I'm using Win10 & Chrome - but that should be irrelevant)
(edit: re-tested via Firefox with same result)
tramperB
Nov 15, 2022Guide
- FURRYe38Nov 16, 2022Guru - Experienced User
Ya I didn't setup any DDNS configurations. Just used some static DNS IP addresses.
Glad you got it working. Be sure to save off a NEW back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
