ivan42295
Oct 07, 2021Aspirant
Nighthawk MR60 Satellite Ethernet Strength
I have the Nighthawk MR60 which comes with the Router and a Satellite. In my new home, i had to set up the modem and Router in the basement and my satellite upstairs. I would like to have my work a...
Oct 07, 2021Guru - Experienced User
Why not put a wired ethernet connection in this area from the MR and install a ethernet Gb LAN switch were, then connect the MS and your gaming system to the LAN switch?
Basements are not recommended placement locations for main wifi routers. Concrete and steel will cause problems with wifi singal coverage.
ivan42295
Thank you for the response.
So I am not sure how that would work as i would still need to run a long ethernet cable to upstairs, no?
So the MR and Modem are positioned in the basement and the MS is upstairs. If i get a switch, wouldn't it need to be connected to the MR (basement)? Then I would still need to run ethernet through the whole house up to the MS and gaming system.
- FURRYe38Oct 07, 2021Guru - Experienced User
Yes you would need a ethernet wire from the MR to the switch at the remote location.
You can try connecting your gaming devices to the MS while it's wireless connected to the MR and see how it goes.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.- ivan42295Oct 07, 2021Aspirant
Yea I think i will try the Ethernet with the MS to start and see... It still gives off pretty strong connection speeds, but it wont be like the MR - I understand that.
the house is small. just under 1,300 sq. ft. The distance between MR and MS is 2 floors. MR is in basement, MS is 2nd floor of house.
Can you get a guess on distance in feet between the MR and MS?
Let us know how it goes though...
